Hello all!
I have booted up the I.MX28 EVK from Linux SD card but there is no gcc in the linux. apt-get and yum etc is also not installed. From where can I download a binary gcc for my embedded Linux 2.6.35 and how to install it... Thanks all
Solved! Go to Solution.
As I know, include gcc into rootfs is not a "common" practice.
Why would you need native build?
You can get a cross-compiler and use a PC to build your application, and then deploy it to your board.
