关于IMX535内核崩溃的问题,求帮助....
Question asked by 浩卢 on Oct 31, 2012
Latest reply on Feb 29, 2016 by jian xiong li
recieve temp:45
{car_trans_main}2012-10-12 10:05:34[0x2dde5460] debug at TransMain.cpp(GetTemp line:3079):      Current temperature is: 45
recieve temp:45
recieve temp:45
rev:65535 sec:35 msec:279 usec:609
recieve temp:45
{car_trans_main}2012-10-12 10:05:37[0x2adc8460] debug at YsTcpClientBase.cpp(Login line:104):   准备登录服务端:193.168.252.12:2001
recieve temp:45
recieve temp:45
recieve temp:45
{car_trans_main}2012-10-12 10:05:40[0x2adc8460] warn  at YsSocket.cpp(Connect line:547):        error in YsSocket's Connect(193.168.252.12:2001), this=0xb9094,err=113,handle=6
{car_trans_main}2012-10-12 10:05:40[0x2adc8460] error at YsTcpClientBase.cpp(Login line:107):   连接服务端失败(193.168.252.12:2001)!
{car_trans_main}2012-10-12 10:05:40[0x2adc8460] error at YsTcpClientBase.cpp(ThreadClient line:317):    登录服务端失败!
{car_trans_main}2012-10-12 10:05:40[0x2dde5460] kernel BUG at arch/arm/mm/dma-mapping.c:409!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = df5d4000
[00000000] *pgd=cf64d031, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#1] PREEMPT
last sysfs file: /sys/devices/virtual/gpio/gpio109/value
Modules linked in:
CPU: 0    Not tainted  (2.6.35.3 #32)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<80038f0c>]    lr : [<80038f08>]    psr: 60000093
sp : df6ffcf0  ip : 0000301b  fp : 0000000e
r10: 20000013  r9 : 00001c00  r8 : fa0bc088
r7 : df450340  r6 : df6e6180  r5 : df450000  r4 : 00000800
r3 : 00000000  r2 : 00000102  r1 : 80883028  r0 : 00000033
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c5387d  Table: cf5d4019  DAC: 00000015
Process car_trans_main (pid: 2186, stack limit = 0xdf6fe2e8)
Stack: (0xdf6ffcf0 to 0xdf700000)
fce0:                                     df450000 8003a8fc dffff810 802a2f08
fd00: df6e69c0 df6e6180 808a983c df450000 df1d3f40 df450000 808a985c 80370a18
fd20: 00000064 80442aa8 00000064 8036a654 7fffffff df646a00 df1d3f40 df6e6180
fd40: df6e6180 df450000 df450000 df5c9400 0000000e 80381e64 df646a00 00000064
fd60: df6e6180 df450000 df1d3f40 80370fd4 df646a5c 00000000 df6e6180 00000064
fd80: 00000000 00000000 00000064 803d1bdc 00000064 80060114 df1385c0 df6fff5c
fda0: de1b99a0 df1385c0 df6ffde4 df6ffdb8 8041a6a8 80060598 df6ffdec df6fe000
fdc0: 00000001 808898e0 00000001 0000000e df6ffee8 00000300 00006540 00000000
fde0: 00000000 00000000 df6fe000 00000000 00000000 df6ffedc 00000064 000b91a4
fe00: df6fe000 00000014 00000036 8036119c df6ffec0 800cf91c 00000000 00000001
fe20: ffffffff 00000000 00000000 00000000 00000000 00000000 df1385c0 800d20ec
fe40: 00000000 00000000 df6ffed4 d662d853 df6ffe88 df69b005 df253b80 dee0f780
fe60: df6ffed4 800d7fb4 df6ffe88 800df174 df6fe000 00000000 00000400 00000000
fe80: 00000084 2dde4a88 00000068 00000000 00000195 00000064 de1b99a0 000000b3
fea0: 00000000 df6fff5c 00000000 00000000 df6ffedc 00000064 000b91a4 df6ffedc
fec0: 00000014 00000000 de1b99a0 00000000 df6ffedc 80361ae4 00000000 03000011
fee0: 00000002 00000000 00000000 00000000 00000400 00000000 00000002 00000000
ff00: 5076a36d 00000000 00000084 00000000 00000084 00000000 00004787 00000000
ff20: df6fff48 2dde4a88 df6fff48 0000002f 000000c3 80036184 df6fe000 00000000
ff40: 2dde4b4c 800cac98 00004787 00000000 0b300001 000081a4 00000001 df6ffedc
ff60: 00000014 df6fff78 00000001 00000000 00000000 00000000 00105350 00000064
ff80: 00000001 00000000 00000400 000b91a4 00000014 00000005 00000122 80036184
ffa0: 00000064 80036000 000b91a4 00000014 00000008 00105350 00000064 00000000
ffc0: 000b91a4 00000014 00000005 00000122 00105350 000b8f40 00000064 00000036
ffe0: 00000000 2dde4b60 2aade16c 2aadf094 80000010 00000008 00000000 00000000
[<80038f0c>] (__bug+0x1c/0x28) from [<8003a8fc>] (___dma_single_cpu_to_dev+0x38/0x64)
[<8003a8fc>] (___dma_single_cpu_to_dev+0x38/0x64) from [<802a2f08>] (fec_enet_start_xmit+0x118/0x1c0)
[<802a2f08>] (fec_enet_start_xmit+0x118/0x1c0) from [<80370a18>] (dev_hard_start_xmit+0x2b0/0x3bc)
[<80370a18>] (dev_hard_start_xmit+0x2b0/0x3bc) from [<80381e64>] (sch_direct_xmit+0x84/0x254)
[<80381e64>] (sch_direct_xmit+0x84/0x254) from [<80370fd4>] (dev_queue_xmit+0x374/0x5b8)
[<80370fd4>] (dev_queue_xmit+0x374/0x5b8) from [<803d1bdc>] (packet_sendmsg+0x8e0/0x974)
[<803d1bdc>] (packet_sendmsg+0x8e0/0x974) from [<8036119c>] (sock_sendmsg+0x88/0xa8)
[<8036119c>] (sock_sendmsg+0x88/0xa8) from [<80361ae4>] (sys_sendto+0xb0/0xd4)
[<80361ae4>] (sys_sendto+0xb0/0xd4) from [<80036000>] (ret_fast_syscall+0x0/0x30)
Code: e1a01000 e59f000c eb0f84e7 e3a03000 (e5833000)
mxc_ipu mxc_ipu: Channel already disabled 9
mxc_ipu mxc_ipu: Channel already uninitialized 9
clk_enable cannot be called in an interrupt context
[<8003a5d8>] (unwind_backtrace+0x0/0xec) from [<800511e8>] (clk_enable+0x34/0x1b0)
[<800511e8>] (clk_enable+0x34/0x1b0) from [<80304e3c>] (ipu_get_clk+0x40/0x58)
[<80304e3c>] (ipu_get_clk+0x40/0x58) from [<80304f08>] (ipu_clear_irq+0x10/0x54)
[<80304f08>] (ipu_clear_irq+0x10/0x54) from [<80216b7c>] (mxcfb_set_par+0x34/0x448)
[<80216b7c>] (mxcfb_set_par+0x34/0x448) from [<80216fec>] (mxcfb_blank+0x5c/0x6c)
[<80216fec>] (mxcfb_blank+0x5c/0x6c) from [<80201b50>] (fb_blank+0x3c/0x68)
[<80201b50>] (fb_blank+0x3c/0x68) from [<8020a510>] (fbcon_blank+0xe8/0x1f4)
[<8020a510>] (fbcon_blank+0xe8/0x1f4) from [<80239f6c>] (do_unblank_screen+0xd8/0x168)
[<80239f6c>] (do_unblank_screen+0xd8/0x168) from [<801f5a04>] (bust_spinlocks+0x20/0x44)
[<801f5a04>] (bust_spinlocks+0x20/0x44) from [<8003942c>] (die+0x234/0x2f4)
[<8003942c>] (die+0x234/0x2f4) from [<8003b46c>] (__do_kernel_fault+0x64/0x84)
[<8003b46c>] (__do_kernel_fault+0x64/0x84) from [<8003b668>] (do_page_fault+0x1dc/0x1f4)
[<8003b668>] (do_page_fault+0x1dc/0x1f4) from [<800352bc>] (do_DataAbort+0x34/0x98)
[<800352bc>] (do_DataAbort+0x34/0x98) from [<80035aac>] (__dabt_svc+0x4c/0x60)
Exception stack(0xdf6ffca8 to 0xdf6ffcf0)
fca0:                   00000033 80883028 00000102 00000000 00000800 df450000
fcc0: df6e6180 df450340 fa0bc088 00001c00 20000013 0000000e 0000301b df6ffcf0
fce0: 80038f08 80038f0c 60000093 ffffffff
[<80035aac>] (__dabt_svc+0x4c/0x60) from [<80038f0c>] (__bug+0x1c/0x28)
kernel BUG at arch/arm/plat-mxc/clock.c:178!
pgd = df5d4000
Internal error: Oops: 817 [#2] PREEMPT
Modules linked in:
pc : [<80038f0c>]    lr : [<80038f08>]    psr: 60000193
sp : df6ff950  ip : 000048e1  fp : 00000000
r10: df0c167c  r9 : 00000000  r8 : df0c1400
r7 : df004000  r6 : 00000000  r5 : 80834be4  r4 : 00000000
r3 : 00000000  r2 : 00000103  r1 : 80883028  r0 : 00000033
Stack: (0xdf6ff950 to 0xdf700000)
f940:                                     800511e8 800511f4 00000000 00000000
f960: 00000000 80304e3c 00000017 80304f08 df0c167c 80216b7c 00002201 8043c918
f980: df21aabc 00541175 00541175 80071e2c 00003b73 a0000193 df6fe000 00000000
f9a0: df0c1400 df004000 df0c167c 00000000 00000000 df004000 df21aa00 00000000
f9c0: 00000000 80216fec 2b6f7464 df0c1400 df0c1400 80201b50 df0c1400 00000000
f9e0: df004000 df21aa00 00000000 df004000 df0c1400 8020a510 00000404 00005027
fa00: 00000404 0000502f 00002201 00005008 df6ffadc 808615ec 00003eb6 800664a0
fa20: 00003eec 00003eec df6fe000 00003eec 00003eec 80066cdc df6ffb17 00000000
fa40: df6ffb17 00000000 808870bf 00000036 0000003c 00000039 df6ffa6e 80067388
fa60: 00000030 60000193 00000122 df6ffae0 df6ffb18 00000001 8078a8f2 8078a8f5
fa80: 8078a8f3 df6ffb20 df6ffae0 801f49e4 ff10210f ffff0008 8085f1cc 0054fbc1
faa0: 0054fbc1 80071e2c df004000 00000000 00000000 80038f10 00000000 00000008
fac0: 7f000000 80239f6c 80883004 df6ffb17 80038f0e 801f5a04 00000001 8003942c
fae0: df6fe2e8 0000000b df1382e0 00000000 651385c0 31306131 20303030 66393565
fb00: 63303030 30626520 65343866 33652037 30333061 28203030 33383565 30303033
fb20: 00002029 00000000 00000817 00000000 df6ffca8 df503d80 00000817 00000000
fb40: 00000817 df6ffca8 0000000e 8003b46c ffffffff df1385c0 00000000 df503d80
fb60: 00000000 8003b668 df5c9a00 00000506 df450000 df6ec3e8 00000006 80380e24
fb80: df6ec3c0 df6ffbbe 808870e7 0000ffff df6ffbbe 808870e7 0000ffff 00000002
fba0: 808874bc 801f3000 00000000 00000000 00200200 0000ffff df6fe000 30390016
fbc0: 00017034 00000000 8087e220 df1dab80 00000001 e115062f 000016d0 8009f010
fbe0: 00000041 df1dabb0 ffffffff 8082aec8 00000817 df6ffca8 00000000 20000193
fc00: 20000013 800352bc 00000404 00005027 00000404 0000502f 00002201 00005008
fc20: df6ffcec 808615ec 00002fee 800664a0 0000301b 0000301b df6fe000 0000301b
fc40: 0000301b 80066cdc df450000 00000000 df450000 00000000 808870bf 0000002d
fc60: 00000033 00000030 df6ffc7e 80067388 00000032 60000093 0000000e 80849a58
fc80: df1d3800 00000057 00000103 00000102 ffffffff df6ffcdc df6e6180 df450340
fca0: fa0bc088 80035aac 00000033 80883028 00000102 00000000 00000800 df450000
fce0: 80038f08 80038f0c 60000093 ffffffff df450000 8003a8fc dffff810 802a2f08
[<80038f0c>] (__bug+0x1c/0x28) from [<800511f4>] (clk_enable+0x40/0x1b0)
[<800511f4>] (clk_enable+0x40/0x1b0) from [<80304e3c>] (ipu_get_clk+0x40/0x58)
debug at TransMain.cpp(GetTemp l---[ end trace 36949942be084861 ]---
ine:3079):      Current temperature iKernel panic - not syncing: Fatal exception in interrupt
s: 45
[<8003a5d8>] (unwind_backtrace+0x0/0xec) from [<8041a22c>] (panic+0x64/0xe0)
[<8041a22c>] (panic+0x64/0xe0) from [<80039498>] (die+0x2a0/0x2f4)
[<80039498>] (die+0x2a0/0x2f4) from [<8003b46c>] (__do_kernel_fault+0x64/0x84)
Exception stack(0xdf6ff908 to 0xdf6ff950)
f900:                   00000033 80883028 00000103 00000000 00000000 80834be4
f920: 00000000 df004000 df0c1400 00000000 df0c167c 00000000 000048e1 df6ff950
f940: 80038f08 80038f0c 60000193 ffffffff
