toñohernández
Looking the best-fit MCU or MPU for your motor control design?
Discussion created by toñohernández Employee on Oct 29, 2012
Looks like some helpful functionality has been added to the Solution Advisor web application.
It enables you to not only select the best-fit processors for your design, but helps you check pin muxing and select the right Tower System modules. Better yet, it has been expanded to included a broader portfolio of products, of which the new Motor Control Wizard will guide you too!
Answer simple questions leading you to recommended solutions from the Kinetis MCU, DSC, PX Series and 8-bit MCU portfolios. Identify additional hardware and software resources...
Freescale’s Motor Control Wizard is like magic!
    http://www.freescale.com/files/graphic/tn/27656-wizard_68x74.jpg
Motor Control Magic!
