Program Flash and NV data
Question asked by Daniele Antonelli on Oct 29, 2012
Latest reply on Oct 29, 2012 by Daniele Antonelli
I have a question about program flash. I'm using K60 with 1024KB of flash memory.
I want to use a little part of this to store some data.
No problem to write and read the flash, my problem is that when I reload my program with debug (or run) command, in internal flash configuration I find the entire flash memory erased.
I try to reserve a portion of flash (in build options) creating a new area from 0xF8000 (the last sector) but it's the same.
How can I do to avoid that my data is overwritten? Is it possible?
Thank you
