_event_open generates Unhandled Exception
panpwr
I am a newbie to MQX, and trying my first steps with this OS, and I am trying to activate a simple event by using the code below.
I manage to create an event by "_event_create" (I can verify that event was initialized by using Keil's MQX OS Support "Events" window in debug mode).
However, when I step over the "event_open", the system hangs, and when I look at the debug window I see that the task status is "Unhandled Interrupt", TD = 0x1fff105c.
How should I proceed from here?
Here is the code:
#define CONFIG_DB_INIT_STRING "ConfigDBInit_EventGroup"
pointer event_configDbInit;
_int_install_unexpected_isr();
_int_unexpected_isr(0);
error = _event_create(CONFIG_DB_INIT_STRING);
if (error != MQX_OK)
    printf("\nevent_create (%s)failed", CONFIG_DB_INIT_STRING);
    _task_block();
error = _event_open(CONFIG_DB_INIT_STRING, event_configDbInit);
    printf("\nTask error code is 0x%1x", _task_errno);
    printf("\nevent_open to %s failed", CONFIG_DB_INIT_STRING);
    _task_block();
Lior.
Tags (2)
DavidS
Hi Lior,
You have:
try:
error = _event_open(CONFIG_DB_INIT_STRING, &event_configDbInit);
Also you can look at the following example to compare:
C:\Freescale\Freescale MQX 3.8\mqx\examples\event
I've found learning the RTOS good to start with chapter #3 of the MQXUG.pdg in C:\Freescale\Freescale MQX 3.8\doc\mqx .  It will walk you through many simple RTOS example located in the ~\mqx\examples path.
David
DavidS
Hi Lior,
You have:
try:
David
panpwr
Thank you David, I haven't noticed this. Probably because event_configDbInit is defined as a pointer, but I haven't noticed that I should send pointer-to-pointer parameter (pointer _PTR_)...
I actually learn using this guide and the supplied examples, which are pretty good for basic understanding. However, are there any online/video courses which you could refer me to, in your website or community?
Thanks again,
Lior.
DavidS
Hi Lior,
Lots of training to find....keyword "find".
Our technical support page has a link to training of various methods:
http://www.freescale.com/webapp/sps/site/homepage.jsp?code=TRAINING_HOME
MQX basics online training:
http://www.freescale.com/webapp/sps/site/training_information.jsp?code=WBNR_VFTF09_AZ146
MQX Product page has many links:
http://www.freescale.com/webapp/sps/site/homepage.jsp?code=MQX_HOME&tid=vanMQX
YouTube:
http://www.youtube.com/user/freescale/videos?view=0
David
