Creating a ramdisk on the i.MX28 EVK
paulbannister
I'm trying to set up a ramdisk on the i.MX28 EVK
I have found a web post that suggests the following
mkdir /tmp/ramdisk; chmod 777 /tmp/ramdisk
mount -t tmpfs -o size=32M tmpfs /tmp/ramdisk/
Both commands appear to complete successfully (No warning/error messages), but when I
ls /mnt
I do not see the ramdisk mounted
I am new to Linux, so I apologise if this is a trivial misunderstanding, but I would appreciate any help offered.
Many thanks!
paulbannister
Many thanks for your help!
SergioSolis
Hello Paul,
Can you please type "mount" in your linux terminal?, you should see a row like this:
tmpfs on /tmp/ramdisk type tmpfs (rw,size=32M)
Here is a small tutorial about tmpfs and ramfs, it may help you clarify any doubt you have:
Overview of RAMFS and TMPFS on Linux
