Starting pipeline after booting
Question asked by Kirill Brilliantov on Oct 19, 2012
Latest reply on Oct 31, 2013 by Kirill Brilliantov
Hello!
I write programm for capture, encode and streaming video with GStreamer 0.10.28 and gst-fsl-plugin-2.0.3 from LTIB.
Now I need start it after boot system. Programm started, but stoped work with next error -  Failed build encoder element!
Follow my code for building encoder element:
enc = gst_element_factory_make("mfw_vpuencoder", "encoder");
if (NULL == enc) {
    ERROR("Failed build encoder element!");
    return FALSE;
Because programm start and work if I start it manually I think problem in enviroment. I try set enviroment GST_REGISTRY on /root/.gstreamer-0.10, LD_LIBRARY_PATH in /usr/lib and GST_PLUGIN_PATH in /usr/lib/gstreamer-0.10, but this is not solve problem.
~ # ls -al /root/.gstreamer-0.10/
-rw-------1 root 1000    269611 Jan  1 00:00 registry.arm.bin
~ # ls /usr/lib/gstreamer-0.10/
libgstaacparse.so       libgstmultipart.so
~ # ls -F /usr/lib
gstreamer-0.10/
libIpuScreenLayer.so.0
lib_H264_dec_arm11_elinux.so
libvpu.so@
libvpu.so.0
How should I modify my programm for solve this problem?
Thank you and excuse my bad english.
