"bitbake -c configure -f virtual/kernel"
shashankreddyvu
when i execute the below command in my terminal during system builder process it is giving following error.
NOTE: Psyco JIT Compiler (http://psyco.sf.net) not available. Install it to increase performance.
NOTE: Handling BitBake files: \ (0405/0405) [100 %]
Parsing of 405 .bb files complete (399 cached, 6 parsed). 536 targets, 1 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 248 of 248 (ID: 6, /home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-sdk-common-dpaa/recipes/linux/linux_3.0.6.bb, do_configure)
NOTE: package linux-3.0.6-r1: task do_configure: Started
NOTE: package linux-3.0.6-r1: task do_configure: Succeeded
NOTE: Tasks Summary: Attempted 248 tasks of which 247 didn't need to be rerun and 0 failed.
mistral@mistral-veriton-series:~/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder$ bitbake -c menuconfig virtual/kernel
NOTE: Running task 249 of 249 (ID: 7, /home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-sdk-common-dpaa/recipes/linux/linux_3.0.6.bb, do_menuconfig)
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-sdk-common-dpaa/recipes/linux/linux_3.0.6.bb do_menuconfig failed
ERROR: Task 7 (/home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-sdk-common-dpaa/recipes/linux/linux_3.0.6.bb, do_menuconfig) failed with 256
ERROR: '/home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-sdk-common-dpaa/recipes/linux/linux_3.0.6.bb' failed
NOTE: package linux-3.0.6-r1: task do_menuconfig: Started
ERROR: Function do_menuconfig failed
NOTE: Task failed: ('function do_menuconfig failed', '/home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/build_p2041rdb_release/work/p2041rdb-linux/linux-3.0.6-r1/temp/log.do_menuconfig.3470')
ERROR: Logfile of failure stored in: /home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/build_p2041rdb_release/work/p2041rdb-linux/linux-3.0.6-r1/temp/log.do_menuconfig.3470
Log data follows:
| (gnome-terminal:3475): GLib-GIO-ERROR **: No GSettings schemas are installed on the system
| /home/mistral/shashank/Material/FREESCALE_BACKUP/CD/installed/QorIQ-DPAA-SDK-20111026-systembuilder/build_p2041rdb_release/work/p2041rdb-linux/linux-3.0.6-r1/temp/run.do_menuconfig.3470: line 484:  3475 Trace/breakpoint trap   (core dumped) gnome-terminal --disable-factory -t "$TERMWINDOWTITLE" -x $SHELLCMDS
NOTE: package linux-3.0.6-r1: task do_menuconfig: Failed
please tell me how to sovle this problem and go to next step
Thank you.
mattsm
With system builder I think you need to look at setting TERMCMD and TERMCMDRUN to acceptable values. Your gnome-terminal looks broken.
mattsm
shashankreddyvu
Thank you for your answer it is absolutely correct, i too tried same thing it worked for me.
I have one more dought
now am running systembuilder for p2041rdb board
now i am at "Add package patches and rebuild package" stage and i am trying to execute below command
bitbake -c clean <package-name>
here what is meant by package-name.
Thank you.
mattsm
The recipe name. So you can look for files in the following format: ${PN}_${VERSION}.bb, here PN = package name.
shashankreddyvu
HI,
Thank you for your answer, based on that i found package name as "rcw-p2041rdb", because of that i gone to next step but i got struct once again, I hope this may be my last dought
now i am in "Add package patches and rebuild package" stage, there they gave as below
Create amend.inc file and add following content in amend.inc file
                SRC_URI += "file://<name-of-patch1> \
                file://<name-of-patch2> \
                file://<name-of-patch n> \
i didn't got what what to replace with "name of patch 1, name of patch 2 ......."
Thank you
mattsm
What error are you seeing with building rcw-p2041rdb? I don't think you should jump in to modify the recipe and/or patches.
-M
shashankreddyvu
Actually there was no error it was successful, The steps give are as below
Add patches for a package (including u-boot and kernel) and rebuild this package as follows:
1. cd <system_builder_installation_path>
2. bitbake -c clean <package-name>
3. Create a new custom collection, for example, mycollection
mkdir -p mycollection/recipes/images
4. Create amend.inc file and add following content in amend.inc file
5. Update the project configuration
./scripts/create-config.py --config-file=fsl-<bsp>/sample-create-config.ini --override-collection mycollection -j 4 -t 2
6. Rebuild this package with added patches.
bitbake <package-name>
so in the 4th step is it not necessary no replace "name of the patch" with patch name. That was the thing i was asking.
Thank you.
mattsm
The 4th step is optional, only if you want to modify the recipe from another layer. In the example they use amend.inc to add some patches.
-M
shashankreddyvu
hi Matthew McClintock,
i want to use "fmc tool" on my host pc, but how to install it i didn't got it, i think the package is located at "/QorIQ-DPAA-SDK-20111026-systembuilder/fsl-packages-private/recipes/fmc/fmc-0.9.7-2".
please help me with how to install fmc tool on host pc,
Thank you.
mattsm
If build for the host, can you git clone the repo and find what you need standalone?
http://git.freescale.com/git/cgit.cgi/ppc/sdk/fmc.git/
shashankreddyvu
Thank you very much for clearing my doughts.
