problem building L2.6.35_11.09.01_ER_source
andrebella
I been trying to build the LTIB but I'm getting this error, it does not tell me much it happens right after I run ./ltib
rpmdb: --force-debian: unknown option
Died at ./ltib line 2340.
traceback:
main::setup_rpmdb:2340
  main::check_rpm_setup:2403
   main::host_checks:1423
    main:542
Started: Mon Oct  8 16:39:53 2012
Ended:   Mon Oct  8 16:39:54 2012
Elapsed: 1 seconds
Build Failed
andrebella
I just read it, I found the solution to the error here [ltib] Diff of /ltib/ltib
I'm using ubuntu 12.04, but I dont think this linux image builder has support for it yet, I'm still getting more errors, I will post more solutions if I can find them.
RandyKrakora
Are you building under Ubuntu? What version?
Did you look here yet?:
https://community.freescale.com/docs/DOC-1442
-Randy
andrebella
