Is there any examples in C language on how to use gst-fsl API's for accelerated video decoding?
Solved! Go to Solution.
I have compiled the given application and got the following problem:
(playvideo:2088): GLib-GObject-WARNING **: g_object_set_valist: object class `GstVpuDec' has no property named `codec-type'
The gstreamer command line is working fine so I think all I need is to add the correct element.
Any suggestions will be much appreciated.
Rgrds,
Tarek
Seems that the string "codec-type" is not being recognized as a property name of some plugin.
You can check the available properties and their options by using:
gst-inspect <plugin name>
Rgds
Rogerio
