LTLIB failing to config for IMX6Q release version L3.0.15_12.04.01
Question asked by somjagadeeshan on Oct 1, 2012
Latest reply on Jul 26, 2013 by Stephane Journaux
Started to build the source packages for IMx6Q baord. The release is L3.0.15_12.04.01_ER_source and end up getting buil dissues with LTLIB.
Here is the log of the error.
Processing: mtd-utils
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try mtd-utils-201006.tar.bz2.md5 from the GPP
http://bitshrine.org/gpp/mtd-utils-201006.tar.bz2.md5:
11:52:39 ERROR 404: Not Found.
Try mtd-utils-201006.tar.bz2 from the GPP
http://bitshrine.org/gpp/mtd-utils-201006.tar.bz2:
Can't get: mtd-utils-201006.tar.bz2 at ./ltib line 790.
Died at ./ltib line 1380.
traceback:
main::build_host_rpms:1380
  main::host_checks:1435
   main:542
Started: Mon Oct  1 11:52:36 2012
Ended:   Mon Oct  1 11:52:39 2012
Elapsed: 3 seconds
These packages failed to build:
mtd-utils
Build Failed
How can this be sorted out. My environment is a Ubuntu 10.04 lucid.
Any inputs will be highly appreciated.
mep
