"frequency change to..." math.h
juanjosestivane
Hi! I'm trying to use math.h library and I have problems on debug mode. I receive a message which says "frequency change to..." and the frequency change constantly. I never reach the result. The MCU is HC9S08QE8.- I am clear? Any help? Thank you!
sebasira
Senior Contributor I
Hi!
Usually, when I have this message is because the MCU hangs at some point. A possible problem is as Kef said, that stack is too small. Other can be invalid address writing.
Another problem related to the stack is that maybe you've got a variable (let's say a buffer 3 bytes long) and you're writing more than this lenght so the routine overwrite the return address on the stack.
I will try using breackpoints to determine where the error ocurrs
Regards!
PS: Please excuse my english.
Sebatian M. Irazabal
Rosario, Santa Fe Argentina
juanjosestivane
Gracias Sebastían! Lo voy a tener en cuenta.
kef
Specialist I
Try increasing STACKSIZE in PRM file. Math functions need a lot of stack.
juanjosestivane
Thank you Edward. I will try!
