How to assign data bus and address bus on diffrent pins like non multiplexing mode
MK60FX512
How to assign data bus and address bus on diffrent pins like non multiplexing mode in Processor expert for K60 MCU?
Petr_H
It's a limitation of Processor Expert that only shared bus can be used. We are planning to improve this in the future versions.
You can find a way of configuring the bus without using Processor Expert in the following application note : http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4393.pdf
best regards
Petr Hradsky
Processor Expert Support Team
Petr_H
best regards
Petr Hradsky
adamcrha
Hello Petr,
any improovement in this feature? It is almost 3 years you said you are planning to improve this in the future versions. I have "Processor Expert for Kinetis    3.0.0.RT7_b1515-0427" and can't still set non-multiplexed flexbus.
Thank you
MK60FX512
Thanks for infomation
but it is take lot time to understand/read the application note or datasheet.
It should be implemented in some GUI like Processor expert. all other company is giving same way like infineon DAVE tool.
