Memory map of MC9S128P
aguo1223
I have a question about memory map .
There have Defined as follow In .PRM file
SGMENTS
PAGE_0E       = READ_ONLY   0x0E8000 TO 0x0EBFFF;
END
Mean that the PAGE_0E is read only and its address is from 0x0E8000 to 0x0EBFFF. But when look up datasheet of MC9S128P find that the address of PAGE_0E is from 0x38000 to 0x3c000.
Please help me? Am I wrong ?
lama
Maybe my help is late but registered into this community just today. The S12P contains global address space  (GPAGE) and local address space (PPAGE). The global space can be used only in the case of flash programming. For all other purposes you have to use PPAGE address space. I would like also to provide you a memory map prepared in excel which provides more info and two examples how to E/W flash by SW. To get files go to mail.yahoo.com ; ID: freescalebox; PASS: fscbox ; subject "S12P memory map". (DO NOT USE THE BOX FOR COMMUNICATION!!!)
Best regards, Ladislav.
lama
Done :smileyhappy:. Please confirm reception. BR Ladislav.
lama
aguo1223
             Sorry about bother you again. I can not login you mail, so , could you send files to my mailbox?
aguo1223@126.com.
    Thank you  again @!
aguo1223
Thank you very much !!!!
