pwm using processor expert
MatteoPioTotta
I would create a EPWM using processor expert,how can i make?
ProcessorExpert
Senior Contributor III
Could you be more specific what do you mean by EPWM? Which CPU do you use?
best regards
Petr Hradsky
Processor Expert Support Team
MatteoPioTotta
EPWM mean EDGE ALIGNED PWM BUT I CAN'T INITIALIZE NEVER THINGS WITH
PROCESSOR EXPERT...I DON'T KNOW BUT DEVICE INITIALIZATION WORK....NOW I
HAVE A NEW PROBLEM WHEN I TRY TO RUN MY PROJECT,AFTER THAT I CORECCTLY
BUILD IT,THAT IS:
"Description:
Launch hook com.freescale.cdt.launch.cw.
TerminateAndRestartHook@14b5f16 failed with internal errors while
checking launch
Explanation:
No details available.Stack Trace:
[Ljava.
lang.StackTraceElement;@1e386bc"
IF YOU CAN RESOLVE THIS PROBLEM I
THANK YOU A LOT.
BEST REGARD
MATTEO TOTTA
Messaggio
originale----
Da: admin@community.freescale.com
Data: 17/09/2012 16.14
A: "Matteo Totta"<matteopiototta@tiscali.it>
Ogg: Re: [Processor Expert
Software] - pwm using processor expert
Processor Expert [https:
//community.freescale.com/people/ProcessorExpert] created the
discussion
"pwm using processor expert"
To view the discussion,
visit: https://community.freescale.com/message/300953#300953
Petr_H
This is strange, we are not aware of such problem.
Please try to reinstall the CodeWarrior and if it doesn't help create a service request using the command Support > Technical Service Request on www.freescale.com.
best regards
Petr Hradsky
MatteoPioTotta
Thanks but now i can use Device Initialization,
This tool don't make any problem.
best regards
Matteo Totta
