Christopher Williamson
SPI NOR, NAND programming via MfgTool
Discussion created by Christopher Williamson Employee on Sep 6, 2012
Latest reply on Oct 8, 2013 by Leonardo Sandoval Gonzalez
[Problem]
Target H/W : SABRE6S-AI board
MFG tools : Mfgtools-Rel-12.09.02_ER_MX6DL_UPDATER
MFG download to SD card is fine, however it failed to SPI-NOR & NAND from SABRE-AI board for MX6 Solo.
Without any modification  I tried with the latest MFG tool releases mentioned above but still got failure. Please find failure logs in attachments.
I wonder if MFG tools has verified with Sabre-AI SPI-NOR * NAND.
[Solution] SPI NOR programming via MFG tool will be supported from ER6 onwards.
NAND is still being worked on.
