I am trying t get standalone OpenVG test running on i.MX50 EVK. Enabled following options in LTIB
[x] amd-gpu-bin-mx51
[x] libz160-bin
Also enabled Device Drivers > MXC support drivers > MXC GPU support > MXC GPU support while kernel compilation.
But running "tiger" test executable throws following error
root@freescale /$ tiger
Press Enter key to terminate
failed to open z430 or no such device
Framebuffer size cannot accomodate panning swap. Falling back to copy forward swap
Caught signal 2, setting flaq to quit.
98 frames, 18.522018 FPS
Do I need to do some other settings to get this working?
Dilip
