Anton Kunz
IMX53 Nand Flash 14-bit ECC u-boot
Discussion created by Anton Kunz on Jul 26, 2012
Hello  We have an IMX53 based board and a Micron 32Gb Flash that requires at least 12-Bit ECC. So we want to use 14-bit ECC with u-boot. Does anyone know if it is possible to use 14-bit ECC with u-boot? Only 4-bit and 8-bit ECC is working in u-boot and not 14-bit ECC. We get RS ECC errors in u-boot when using 14-bit ECC setting.
