Artur Artur
imx23 step-by-step
Discussion created by Artur Artur on Jul 16, 2012
Hello everyone.  We use WINCE 6. Board made on the basis of imx23. BSP used by freescale for imx23. But the BSP is designed for use with demokit (ivk23), which used other nand, and ddr 2x64mb, we are using only 64mb. For this reason, eboot does not run on our board. Can you tell which files need to be adjusted, and what parameters to correct for those chips that we used.
