Hello
Are you looking for a way to periodically refresh the content of the opened memory or expression window while application is running?
You can activate that as follows:
- Open the project in CodeWarrior
- Open the Target settings dialog (press ALT + F7)
- Switch to "Debugger Settings" Panel
- Check "Update data every ... check box and adjust the period there.
- Close the target settings dialog pressing on OK.
CrasyCat
