Setting bootargs automatically
Goi
Is it possible to set bootargs automatically after flashing the image, without entering them manually in the console after every flash?
Thanks.
MassimoBonazzi
Modify env_something.c file in /rpm/BUILD/u-boot*/common/env_mmc.c to match your env var and rebuild uboot.
Once it boots it wont find the enviroment and it will use the default you provided in the .c file.
