GPIO programming for iMX53SMD
SandeepKorrapat
Hi All,
I am pretty new to embedded programming. I would like to write a program Turn ON / OFF an LED. But, am little confused as to how one can configure IOMUX to select GPIO mode from a c/c++ code.
It would be great if someone can provide a sample code for this.
Thanks in advance.
-Sandeep
SandeepKorrapat
Hi Miroslav,
Yes I did, the problem with the other topics I have found are explained through API calls of Liunx.
For my project, I cannot use Linux calls, I have the memory regions of GPIO and the IOMUX registers from the refenrece manual. Now I have to use these address regions to set the IOMUX mode to GPIO and toggle GPIO.
It would be great if someone can provide an example for this.
MiroslavIMX53QS
