U-Boot Environmental Variables
ShaneKaiser
Hello Everyone,
I have a question regarding a U-Boot environment variable:
loadaddr=70800000
mmc read ${loadaddr} 0x800 0x1800; bootm
What exactly is the mmc command doing here? How does one come up with loadaddr=70800000?
From what I understand U-Boot will read data from the sd card at 2048*512=1MB (starting location of uImage on the sd card) and keep reading for 6144*512=3MB (the size of the kernel) and take this data and copy it to address 0x70800000 in memory? So U-Boot is installing the kernel at the memory address 0x70800000?
Yuri
I am not sure if kernel decompressor  is position independent, it may be build to use absolute addresses (0x70800000).
ShaneKaiser
Thanks for the response Yuri.
Why the memory address 0x70800000? I have noticed some people use other memory addresses. What is the thinking here?
Yuri
You are right.
