ying zhu
console debug problem for CW for Coldfire 6.3
Discussion created by ying zhu on Jun 6, 2007
Latest reply on Jun 6, 2007 by CompilerGuru
Hi, I'm using Codewarrior for Coldfire architectures, v6.3, targeting a M52233DEMO. I followed the quick start instruction's setting and example to build and run the example project,  when doing console debug, a window appears which says: unable to use the plugin"CCS_CF_Protocol_Plugin". It is licensed and a valid license key was found. CFCCSProtocolplugin: Can't connect to CCS. But when I  do UART debug, it works. How to solve this console debug problem. Thanks so much
J2MEJediMaster added CW type and version to subject line
Message Edited by J2MEJediMaster on 2007-06-07 10:14 AM
