1080i de-interlace support for iMX53, based on L2.6.35_11.09.01 BSP
qiang_li-mpu_se
    Due to IM53 IPU VDIC hardware limitation, the input and output size for VDIC is 968*1024, so for 1080i, it can't be supported ditectly, we need use split mode to support 1080i de-interlace.
    The related patched can be downloaded from my blog: http://imxcommunity.org/profiles/blogs/1080i-de-interlance-support-for-imx53-based-on-l2-6-35-11-09-...
stevetsai
Did not find your blog. Coud you update your link?
admin
Specialist II
