How to port QT Embedded 4.6.0/Framebuffer on i.MX53 LTIB 11.09 release -blog archive
AlanZhang
Contributor V
Step 1. Install i.MX53 11.09 release with AAC, MMCODEC, 1109 patches;
             NOTE: Only apply amd-gpu-bin for Framebuffer. DO NOT use amd-gpu-x11-bin that is for X11.
Step 2: Download qt-everywhere-opensource-src-4.6.0.tar.gz;
Step 2: ./ltib -m prep -p qt-everywhere-opensource-src
Step 3: Use the attached files to replace the original files respectively. One is "rpm/BUILD/qt-everywhere-opensource-src-4.6.0/mkspecs/qws/linux-g++-mx/qmake.conf"qmake.conf, the other is "dist/lfs-5.1/qt/qt-embedded.spec"qt-embedded.spec.
Step 4: ./ltib -m scbuild -p qt-embedded.spec
Then you get QT running. Note: You need to "scbuild", and "scdeploy" libxml2, sqlite2, libjpeg, freetype, libpng before the successful building QT. Add "export QT_QWS_FONTDIR=/usr/lib/fonts" in /etc/profile as global env setting. If you want to browse internet, set /etc/resolv.conf like mine as following:
# nameserver ip address
domain ap.freescale.net
search ap.freescale.net
nameserver 10.192.130.201
nameserver 10.211.0.131
nameserver 10.211.0.3
Examples:
/usr/local/Trolltech/demos/embedded/fluidlauncher/fluidlauncher -qws
neildsimpson
Thanks for the post, but the links are broken - can you fix them please?
