jk t
IMX53 QBS - Initial setup
Discussion created by jk t on May 31, 2012
Latest reply on Jun 5, 2012 by Yinzhe Lu
Dear All,
I just started to work on iMX53 QSB board.
I am using the virtual machine setup for Ubuntu in my windows PC, as mentioned in the README_Ubuntu_VM.pdf.
I have 2 queries on this.
1. With that setup, I prepared the micro SD card and tried to boot the board.
    The u-boot loaded properly and linux started to load, but while loading the file system it got stuck.
    i.e. I am not getting the User Name and Password prompt. The VGA display shows the TUX symbol.
    how to proceed on this?
 (note: while updating the micro SD card with "dd" command, it took very long time)
2. I have gone through the LTIB script file and came to know the path of U-boot source. Linux source, rootfs. (rootfs - /home/lucid/ltib/rootfs)
As per my previous query, I got doubt in rootfs present in uSDcard (as the copy took very long time), now I formatted the uSD and copied the rootfs contents to it.
with this rootfs contents, in console output I can see the UserName and Password prompt.
But,
    a. The password: lucid (as mentioned in the doc) is not matching. (what is the password?)
    b. In the VGA display, only Tux symbol is there but no user name/pw prompt window.
how to overcome these issues?
any pointers and suggestions would be more helpful
thanks and regards,
jk
