DDR3 CLK termination
FreeScaleLogin
We are in the rudimentary stage of Schemtic design of i.MX535 .DDR3 clock lines has been terminated with 200 ohm res in the ref schematic of Sabre.
Question is , In general, differential clock will be terminated by 100 ohm . Can anyone explain, why they double the resistor value in Sabre design?
UKR
T_I
I think to same.So I asked Freescale this Question.
Freescale's answer is "
One can try 100 Ohm also. 200Ohm was proved as sufficient for obtaining best results.
