Poor Performance - i.MX53 Qt 4.7.4, hellogl_es2 example
DD1z
I am getting really poor performance on the i.MX 53 with Qt4.7.4 and the hellogl_es2 example.
The fps is showing about 13 fps. I installed Qt with the X-server.
The screen resolution is 1024x786.
Any ideask, why the performance is so poor?
Tags (2)
santiagoperez
HI DD1z,
could you fix the problem?. I'm having the same issue, even worst, just 6fps.
KrishnaPavan
on i.MX51 amd-gpu-bin-mx51
santiagoperez
Could you run Qt over the frame buffer with GPU enabled?. I had no success and in several posts it is said you need to enable a specific plugin.
Thanks in advance,
DD1z
Which screen driver are you using?
KrishnaPavan
I use without X11 libs and it's working fine.
