Filippo Visocchi
LTIB and make
Discussion created by Filippo Visocchi on May 10, 2012
Latest reply on Jun 17, 2013 by Leonardo Sandoval Gonzalez
Hi all,
this is only to share some informations.
I'm using Fedora16, with L2.6.35_11.09.01_ER_source_bundle for the START_R board.
gstreamer fails to compile inside ltib, complaining about a Makefile corrupt.
Fedora16 has make 3.82.
Changing make to version 3.81 solves the problem, and the build finishes with success.
sparse-0.4 has a problem too, in the parse.h file.
I have removed some lines in parse.h as explained here , and everything compiles fine.
On a Ubuntu 12.04 installation, the make is a 3.81, so it's ok, but the sparse problem is there.
Cheers
Filippo
