iMX25 external RTC
iMX25 external RTC
Venku
Hello I am trying to use an external RTC (m41t81s). Enabled this option under RTC in menuconfig, didn't yield any results. No device under /dev for rtc, neither an entry in sys/bus..
Under I2C RTC, have enabled M41t80.
I have removed the DryIce RTC.
Are there any tweaks reqd in BSP for this to run?
Venkat
Tags (2)
Venku
Update : RTC works
mxc25_3stack.c:
i2c_board_info mxc_i2c_board_info __initdata = {
.type = "m41t81s",
.addr = 0x68,
entry for this i2c device was reqd in the structure for it to work..
Venkat
