Ernest Snaith
16 and 32 bit comnination
Discussion created by Ernest Snaith on May 13, 2007
Latest reply on May 14, 2007 by Ernest Snaith
I have the timer running as well as secondary counter which increments on timer overflow. I am storing values of both at regualr intervals. Is there away of storing both 16 bit values as a long integer type to be used in expressions at a later time? Also is the reverse possible? accessing high and low parts of long int.
Cheers
