Chaim Attar
LTIB Build Failed
Discussion created by Chaim Attar on Mar 26, 2012
trying :
./ltib
What's wrong??
The HostConfiglog:
Processing platform: host support ===================================
Processing: rpm-fs ==================== error: cannot open Name index using db3 - No such file or directory (2) error: cannot open Name index using db3 - No such file or directory (2) ERROR: /tmp/rpm-lucid/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm would clobber '/reescale/ltib' traceback:  main::check_host_clobber:2674   main::build_rpm:906    main::f_buildrpms:980     main::check_rpm_setup:2405      main::host_checks:1423       main:542
Started: Mon Mar 26 23:22:35 2012 Ended:   Mon Mar 26 23:22:36 2012 Elapsed: 1 seconds
Build Failed
