Building libsocketcan
UVicEcoCar2
When we were trying to build the libsocketcan using the method "./litb -p 'pkg_name' ". the following error occurred:
lucid@ubuntu:~/Desktop/imx53_ard_11.05/ltib$ ./ltib -p libsocketcan
Processing platform: Freescale iMX5x Based Boards
using config/platform/imx/.config
Cannot find spec file that contains the package name libsocketcan.
If necessary please give the whole spec file name (with the .spec extension).
traceback:
main::mk_buildlist:1917
main::f_buildrpms:974
main:560
Started: Tue Mar 13 15:54:58 2012
Ended: Tue Mar 13 15:54:59 2012
Elapsed: 1 seconds
Build Failed
Exiting on error or interrupt
Could you tell us what to look for to fix this error?
Thank you
UVic
Tags (2)
Frias
Contributor V
Please follow the instructions on the page 45 of the presentation, you need to copy the spec files and sources to the appropriate folder, see:
