Gustavo Costa
Installing Ltib
Discussion created by Gustavo Costa on Mar 8, 2012
Latest reply on Mar 8, 2012 by KrishnaPavan
I'm trying to install Ltib in linux 2.6.35.3 in Ubuntu 9.10 and after I ran successfully "./ltib/install" I try to run ./ltib but this error had occurred.
   distak-pc@distak-pc:~/iMX51/linux-2.6.35.3/ltib$ ./ltib
   Installing host support packages.
   This only needs to be done once per host, but may take up to
   an hour to complete ...
   If an error occurs, a log file with the full output may be found in:
   /home/distak-pc/iMX51/linux-2.6.35.3/ltib/host_config.log
   Exiting on error or interrupt
   Please see >> /home/distak-pc/iMX51/linux-2.6.35.3/ltib/host_config.log for details
What should I do now?
Follows the  host_config.log.
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/distak-pc/iMX51/linux-2.6.35.3/ltib/dist/lfs-5.1/mtd-utils/mtd-utils.spec
Building target platforms: i686
Building for target i686
Executing(%prep): /bin/sh -e /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf mtd-utils
+ /bin/bzip2 -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/mtd-utils-201006.tar.bz2
+ tar -xvvf -
tar: Record size = 8 blocks
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/
-rw-r----- r65388/s2101   1418 2010-01-15 14:12 mtd-utils/flash_unlock.c
-rw-r----- r65388/s2101   7788 2010-01-15 14:12 mtd-utils/nftldump.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/mkfs.ubifs/
-rw-r----- r65388/s2101     12 2010-01-15 14:12 mtd-utils/mkfs.ubifs/.gitignore
-rw-r----- r65388/s2101  15842 2010-01-15 14:12 mtd-utils/mkfs.ubifs/lpt.c
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc32.c
-rw-r----- r65388/s2101   4454 2010-01-15 14:12 mtd-utils/mkfs.ubifs/mkfs.ubifs.h
-rw-r----- r65388/s2101   5078 2010-01-15 14:12 mtd-utils/mkfs.ubifs/key.h
-rw-r----- r65388/s2101  14732 2010-01-15 14:12 mtd-utils/mkfs.ubifs/devtable.c
-rw-r----- r65388/s2101    599 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc16.h
-rw-r----- r65388/s2101    608 2010-01-15 14:12 mtd-utils/mkfs.ubifs/README
-rw-r----- r65388/s2101  61496 2010-01-15 14:12 mtd-utils/mkfs.ubifs/mkfs.ubifs.c
-rw-r----- r65388/s2101   1437 2010-01-15 14:12 mtd-utils/mkfs.ubifs/compr.h
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/mkfs.ubifs/COPYING
-rw-r----- r65388/s2101    679 2010-01-15 14:12 mtd-utils/mkfs.ubifs/Makefile
-rw-r----- r65388/s2101    467 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc32.h
-rw-r----- r65388/s2101  21934 2010-01-15 14:12 mtd-utils/mkfs.ubifs/ubifs-media.h
-rw-r----- r65388/s2101   1990 2010-01-15 14:12 mtd-utils/mkfs.ubifs/defs.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/
-rw-r----- r65388/s2101   4092 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.h
-rw-r----- r65388/s2101   9031 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable.c
-rw-r----- r65388/s2101   2961 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_private.h
-rw-r----- r65388/s2101   5789 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.c
-rw-r----- r65388/s2101   7401 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable.h
-rw-r----- r65388/s2101   2618 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc16.c
-rw-r----- r65388/s2101    980 2010-01-15 14:12 mtd-utils/mkfs.ubifs/lpt.h
-rw-r----- r65388/s2101   4639 2010-01-15 14:12 mtd-utils/mkfs.ubifs/compr.c
-rw-r----- r65388/s2101  11457 2010-01-15 14:12 mtd-utils/mkfs.ubifs/ubifs.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/
-rw-r----- r65388/s2101    124 2010-01-15 14:12 mtd-utils/ubi-utils/.gitignore
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/src/
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/ubi-utils/src/crc32.c
-rw-r----- r65388/s2101  24406 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiformat.c
-rw-r----- r65388/s2101   6589 2010-01-15 14:12 mtd-utils/ubi-utils/src/dictionary.h
-rw-r----- r65388/s2101  10409 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubigen.c
-rw-r----- r65388/s2101   3038 2010-01-15 14:12 mtd-utils/ubi-utils/src/common.h
-rw-r----- r65388/s2101  20096 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubinize.c
-rw-r----- r65388/s2101   5883 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiattach.c
-rw-r----- r65388/s2101  28157 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubi.c
-rw-r----- r65388/s2101   8628 2010-01-15 14:12 mtd-utils/ubi-utils/src/mtdinfo.c
-rw-r----- r65388/s2101   2873 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubicrc32.c
-rw-r----- r65388/s2101   5180 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirmvol.c
-rw-r----- r65388/s2101    358 2010-01-15 14:12 mtd-utils/ubi-utils/src/crc32.h
-rw-r----- r65388/s2101   4031 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirename.c
-rw-r----- r65388/s2101   7371 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiupdatevol.c
-rw-r----- r65388/s2101   8405 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubimkvol.c
-rw-r----- r65388/s2101  24434 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd.c
-rw-r----- r65388/s2101  20010 2010-01-15 14:12 mtd-utils/ubi-utils/src/libiniparser.c
-rw-r----- r65388/s2101  11445 2010-01-15 14:12 mtd-utils/ubi-utils/src/dictionary.c
-rw-r----- r65388/s2101   4258 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubi_int.h
-rw-r----- r65388/s2101   8694 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd_legacy.c
-rw-r----- r65388/s2101  10994 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubinfo.c
-rw-r----- r65388/s2101   4986 2010-01-15 14:12 mtd-utils/ubi-utils/src/common.c
-rw-r----- r65388/s2101   5572 2010-01-15 14:12 mtd-utils/ubi-utils/src/libscan.c
-rw-r----- r65388/s2101   4873 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubidetach.c
-rw-r----- r65388/s2101   2668 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd_int.h
-rw-r----- r65388/s2101   6380 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirsvol.c
-rw-r----- r65388/s2101   1712 2010-01-15 14:12 mtd-utils/ubi-utils/Makefile
-rw-r----- r65388/s2101   1083 2010-01-15 14:12 mtd-utils/ubi-utils/LICENSE.libiniparser
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/
-rw-r----- r65388/s2101     90 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/.gitignore
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/
-rw-r----- r65388/s2101   1662 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/inject_biterror.pl
-rwxr-x--- r65388/s2101   2053 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/run_all.sh
-rw-r----- r65388/s2101   3519 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/unubi_test.sh
-rw-r----- r65388/s2101   3938 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/bin2nand2bin_test.sh
-rwxr-x--- r65388/s2101   2117 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/jffs2_test.sh
-rw-r----- r65388/s2101    266 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/README
-rwxr-x--- r65388/s2101    663 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/mkdevs.pl
-rw-r----- r65388/s2101   1600 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/Makefile
-rwxr-x--- r65388/s2101   5858 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_tools_test.sh
-rw-r----- r65388/s2101    380 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/test.cfg
-rw-r----- r65388/s2101    100 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/TODO
-rw-r----- r65388/s2101    517 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/pdd.txt
-rwxr-x--- r65388/s2101   7870 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_test.sh
-rwxr-x--- r65388/s2101   9197 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_jffs2_test.sh
-rw-r----- r65388/s2101    413 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/testcases.txt
-rw-r----- r65388/s2101   4599 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/UBI.TXT
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/
-rw-r----- r65388/s2101   2333 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/list.c
-rw-r----- r65388/s2101   4410 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/error.c
-rw-r----- r65388/s2101   7371 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi.h
-rw-r----- r65388/s2101   2688 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi_analyze.h
-rw-r----- r65388/s2101   2152 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/crc32.c
-rw-r----- r65388/s2101  11041 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubigen.c
-rw-r----- r65388/s2101  31016 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libpfiflash.c
-rw-r----- r65388/s2101  10464 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/reader.c
-rw-r----- r65388/s2101  10969 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pddcustomize.c
-rw-r----- r65388/s2101   8132 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bin2nand.c
-rw-r----- r65388/s2101  19720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubi.c
-rw-r----- r65388/s2101   1771 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/list.h
-rw-r----- r65388/s2101   2260 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/error.h
-rw-r----- r65388/s2101  24475 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi.c
-rw-r----- r65388/s2101   7011 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash.c
-rw-r----- r65388/s2101   1020 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandecc.h
-rw-r----- r65388/s2101   2280 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash.h
-rw-r----- r65388/s2101   1213 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/crc32.h
-rw-r----- r65388/s2101  10013 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi.c
-rw-r----- r65388/s2101  12422 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bootenv.h
-rw-r----- r65388/s2101   5056 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandecc.c
-rw-r----- r65388/s2101    987 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/example_ubi.h
-rw-r----- r65388/s2101    994 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/config.h
-rw-r----- r65388/s2101  11340 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi_analyze.c
-rw-r----- r65388/s2101   9720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubigen.c
-rw-r----- r65388/s2101  12118 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nand2bin.c
-rw-r----- r65388/s2101   4657 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubi_int.h
-rw-r----- r65388/s2101   5594 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubimirror.c
-rw-r----- r65388/s2101   7030 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/hashmap.c
-rw-r----- r65388/s2101  19507 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bootenv.c
-rw-r----- r65388/s2101   5077 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubimirror.c
-rw-r----- r65388/s2101   1755 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/hashmap.h
-rw-r----- r65388/s2101   4379 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubigen.h
-rw-r----- r65388/s2101   4135 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/mkbootenv.c
-rw-r----- r65388/s2101   2438 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/reader.h
-rw-r----- r65388/s2101   2331 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubimirror.h
-rw-r----- r65388/s2101  15488 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi2bin.c
-rw-r----- r65388/s2101   1353 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/peb.h
-rw-r----- r65388/s2101   6720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/eb_chain.c
-rw-r----- r65388/s2101   2256 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash_error.h
-rw-r----- r65388/s2101   2420 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandcorr.c
-rw-r----- r65388/s2101   2175 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/peb.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/
-rw-r----- r65388/s2101    607 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/f64_nor_sample.cfg
-rwxr-x--- r65388/s2101   1372 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/ubicrc32.pl
-rwxr-x--- r65388/s2101  16982 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/mkpfi
-rw-r----- r65388/s2101    578 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/f128_nand_sample.cfg
-rw-r----- r65388/s2101   8112 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/README
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/inc/
-rw-r----- r65388/s2101   8010 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/inc/libubi.h
-rw-r----- r65388/s2101   1602 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/Makefile
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/doc/
-rw-r----- r65388/s2101   5241 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/doc/unubi.roff
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/lib/
-rw-r----- r65388/s2101   2090 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/lib/Makefile.am
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/include/
-rw-r----- r65388/s2101  10270 2010-01-15 14:12 mtd-utils/ubi-utils/include/libiniparser.h
-rw-r----- r65388/s2101   3509 2010-01-15 14:12 mtd-utils/ubi-utils/include/libubigen.h
-rw-r----- r65388/s2101   3156 2010-01-15 14:12 mtd-utils/ubi-utils/include/libscan.h
-rw-r----- r65388/s2101   7247 2010-01-15 14:12 mtd-utils/ubi-utils/include/libmtd.h
-rw-r----- r65388/s2101  14786 2010-01-15 14:12 mtd-utils/ubi-utils/include/libubi.h
-rw-r----- r65388/s2101    657 2010-01-15 14:12 mtd-utils/.gitignore
-rw-r----- r65388/s2101   7400 2010-01-15 14:12 mtd-utils/flash_eraseall.c
-rw-r----- r65388/s2101   6676 2010-01-15 14:12 mtd-utils/mkfs.jffs2.1
-rw-r----- r65388/s2101   3264 2010-01-15 14:12 mtd-utils/doc_loadbios.c
-rw-r----- r65388/s2101  17841 2010-01-15 14:12 mtd-utils/nandwrite.c
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/crc32.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/ubi-tests/
-rw-r----- r65388/s2101   2484 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_paral.c
-rw-r----- r65388/s2101   4265 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_basic.c
-rwxr-x--- r65388/s2101    616 2010-01-15 14:12 mtd-utils/tests/ubi-tests/runtests.sh
-rw-r----- r65388/s2101    102 2010-01-15 14:12 mtd-utils/tests/ubi-tests/.gitignore
-rw-r----- r65388/s2101   4292 2010-01-15 14:12 mtd-utils/tests/ubi-tests/common.h
-rw-r----- r65388/s2101  19260 2010-01-15 14:12 mtd-utils/tests/ubi-tests/integ.c
-rw-r----- r65388/s2101   6536 2010-01-15 14:12 mtd-utils/tests/ubi-tests/rsvol.c
-rw-r----- r65388/s2101   7104 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_update.c
-rw-r----- r65388/s2101    818 2010-01-15 14:12 mtd-utils/tests/ubi-tests/Makefile
-rw-r----- r65388/s2101   8619 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_read.c
-rw-r----- r65388/s2101   7434 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_paral.c
-rw-r----- r65388/s2101   3023 2010-01-15 14:12 mtd-utils/tests/ubi-tests/volrefcnt.c
-rw-r----- r65388/s2101   5446 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_basic.c
-rw-r----- r65388/s2101   7349 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_bad.c
-rw-r----- r65388/s2101   8221 2010-01-15 14:12 mtd-utils/tests/ubi-tests/common.c
-rw-r----- r65388/s2101   1253 2010-01-15 14:12 mtd-utils/tests/ubi-tests/README.udev
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/jittertest/
-rw-r----- r65388/s2101  34580 2010-01-15 14:12 mtd-utils/tests/jittertest/JitterTest.c
-rw-r----- r65388/s2101   6736 2010-01-15 14:12 mtd-utils/tests/jittertest/README
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/tests/jittertest/COPYING
-rw-r----- r65388/s2101   1788 2010-01-15 14:12 mtd-utils/tests/jittertest/Makefile
-rw-r----- r65388/s2101    251 2010-01-15 14:12 mtd-utils/tests/jittertest/filljffs2.sh
-rw-r----- r65388/s2101  10267 2010-01-15 14:12 mtd-utils/tests/jittertest/plotJittervsFill.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/checkfs/
-rw-r----- r65388/s2101    216 2010-01-15 14:12 mtd-utils/tests/checkfs/common.h
-rw-r----- r65388/s2101   7002 2010-01-15 14:12 mtd-utils/tests/checkfs/README
-rw-r----- r65388/s2101    291 2010-01-15 14:12 mtd-utils/tests/checkfs/Makefile
-rw-r----- r65388/s2101  21769 2010-01-15 14:12 mtd-utils/tests/checkfs/checkfs.c
-rw-r----- r65388/s2101   1181 2010-01-15 14:12 mtd-utils/tests/checkfs/comm.c
-rw-r----- r65388/s2101   8520 2010-01-15 14:12 mtd-utils/tests/checkfs/makefiles.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/
-rw-r----- r65388/s2101   1510 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/free_space.c
-rw-r----- r65388/s2101    250 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/Makefile
-rw-r----- r65388/s2101   5272 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/fstest_monitor.c
-rwxr-x--- r65388/s2101    717 2010-01-15 14:12 mtd-utils/tests/fs-tests/run_all.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/
-rw-r----- r65388/s2101    150 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/Makefile
-rwxr-x--- r65388/s2101    644 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/stress01.sh
-rwxr-x--- r65388/s2101   1124 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/stress00.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/
-rw-r----- r65388/s2101   3129 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_3.c
-rw-r----- r65388/s2101   3011 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_2.c
-rw-r----- r65388/s2101   5281 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndwrite00.c
-rw-r----- r65388/s2101   5322 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/gcd_hupper.c
-rw-r----- r65388/s2101   5820 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/fwrite00.c
-rw-r----- r65388/s2101   3609 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/pdfrun.c
-rw-r----- r65388/s2101    511 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/Makefile
-rw-r----- r65388/s2101   3692 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rmdir00.c
-rw-r----- r65388/s2101  10320 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndrm99.c
-rw-r----- r65388/s2101   2655 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_1.c
-rw-r----- r65388/s2101   4329 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndrm00.c
-rw-r----- r65388/s2101    137 2010-01-15 14:12 mtd-utils/tests/fs-tests/Makefile
-rwxr-x--- r65388/s2101   1420 2010-01-15 14:12 mtd-utils/tests/fs-tests/help_all.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/
-rw-r----- r65388/s2101   4330 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/test_1.c
-rw-r----- r65388/s2101    350 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/Makefile
-rw-r----- r65388/s2101   6356 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/test_2.c
-rw-r----- r65388/s2101   5069 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/perf.c
-rw-r----- r65388/s2101   2668 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/ftrunc.c
-rw-r----- r65388/s2101   4633 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/orph.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/
-rw-r----- r65388/s2101    166 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/Makefile
-rw-r----- r65388/s2101   7328 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/tests.h
-rw-r----- r65388/s2101  28463 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/tests.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/
-rw-r----- r65388/s2101  46654 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/integck.c
-rw-r----- r65388/s2101    259 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/Makefile
-rw-r----- r65388/s2101   6027 2010-01-15 14:12 mtd-utils/nandtest.c
-rw-r----- r65388/s2101   3894 2010-01-15 14:12 mtd-utils/compr_zlib.c
-rw-r----- r65388/s2101   4247 2010-01-15 14:12 mtd-utils/device_table.txt
-rw-r----- r65388/s2101    366 2010-01-15 14:12 mtd-utils/feature-removal-schedule.txt
-rw-r----- r65388/s2101   2957 2010-01-15 14:12 mtd-utils/compr_lzo.c
-rw-r----- r65388/s2101   3388 2010-01-15 14:12 mtd-utils/rfdformat.c
-rw-r----- r65388/s2101   3363 2010-01-15 14:12 mtd-utils/compr.h
-rw-r----- r65388/s2101   1772 2010-01-15 14:12 mtd-utils/common.mk
-rw-r----- r65388/s2101   9520 2010-01-15 14:12 mtd-utils/mtd_debug.c
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/COPYING
-rw-r----- r65388/s2101   4860 2010-01-15 14:12 mtd-utils/summary.h
-rw-r----- r65388/s2101   1728 2010-01-15 14:12 mtd-utils/Makefile
-rw-r----- r65388/s2101   5173 2010-01-15 14:12 mtd-utils/rbtree.h
-rw-r----- r65388/s2101    352 2010-01-15 14:12 mtd-utils/crc32.h
-rw-r----- r65388/s2101   3687 2010-01-15 14:12 mtd-utils/flash_erase.c
-rw-r----- r65388/s2101  21151 2010-01-15 14:12 mtd-utils/jffs2reader.c
-rw-r----- r65388/s2101   2661 2010-01-15 14:12 mtd-utils/compr_rtime.c
-rw-r----- r65388/s2101   1780 2010-01-15 14:12 mtd-utils/flash_lock.c
-rw-r----- r65388/s2101  22200 2010-01-15 14:12 mtd-utils/jffs2dump.c
-rw-r----- r65388/s2101   8869 2010-01-15 14:12 mtd-utils/docfdisk.c
-rw-r----- r65388/s2101   9445 2010-01-15 14:12 mtd-utils/ftl_format.c
-rw-r----- r65388/s2101   1041 2010-01-15 14:12 mtd-utils/flash_otp_dump.c
-rw-r----- r65388/s2101  27082 2010-01-15 14:12 mtd-utils/sumtool.c
-rw-r----- r65388/s2101  14808 2010-01-15 14:12 mtd-utils/recv_image.c
-rw-r----- r65388/s2101  10786 2010-01-15 14:12 mtd-utils/nanddump.c
-rw-r----- r65388/s2101   6536 2010-01-15 14:12 mtd-utils/ftl_check.c
-rw-r----- r65388/s2101   1264 2010-01-15 14:12 mtd-utils/flash_otp_info.c
-rw-r----- r65388/s2101  12402 2010-01-15 14:12 mtd-utils/nftl_format.c
-rw-r----- r65388/s2101   1539 2010-01-15 14:12 mtd-utils/mcast_image.h
-rw-r----- r65388/s2101   7811 2010-01-15 14:12 mtd-utils/serve_image.c
-rw-r----- r65388/s2101   8641 2010-01-15 14:12 mtd-utils/jffs-dump.c
-rwxr-x--- r65388/s2101   4309 2010-01-15 14:12 mtd-utils/load_nandsim.sh
-rwxr-x--- r65388/s2101    786 2010-01-15 14:12 mtd-utils/MAKEDEV
-rw-r----- r65388/s2101    727 2010-01-15 14:12 mtd-utils/mtd-utils.spec
-rw-r----- r65388/s2101  14734 2010-01-15 14:12 mtd-utils/compr.c
-rw-r----- r65388/s2101   1047 2010-01-15 14:12 mtd-utils/flash_info.c
-rw-r----- r65388/s2101   1969 2010-01-15 14:12 mtd-utils/flash_otp_write.c
-rw-r----- r65388/s2101   8624 2010-01-15 14:12 mtd-utils/rbtree.c
-rw-r----- r65388/s2101   1980 2010-01-15 14:12 mtd-utils/fectest.c
-rw-r----- r65388/s2101   1534 2010-01-15 14:12 mtd-utils/flash_otp_lock.c
-rw-r----- r65388/s2101  10932 2010-01-15 14:12 mtd-utils/flashcp.c
-rw-r----- r65388/s2101   7281 2010-01-15 14:12 mtd-utils/rfddump.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/linux/
-rw-r----- r65388/s2101   7034 2010-01-15 14:12 mtd-utils/include/linux/jffs2.h
-rw-r----- r65388/s2101   1903 2010-01-15 14:12 mtd-utils/include/mtd_swab.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/mtd/
-rw-r----- r65388/s2101   2646 2010-01-15 14:12 mtd-utils/include/mtd/ftl-user.h
-rw-r----- r65388/s2101   2371 2010-01-15 14:12 mtd-utils/include/mtd/jffs2-user.h
-rw-r----- r65388/s2101  15492 2010-01-15 14:12 mtd-utils/include/mtd/ubi-user.h
-rw-r----- r65388/s2101  16929 2010-01-15 14:12 mtd-utils/include/mtd/ubi-media.h
-rw-r----- r65388/s2101   4356 2010-01-15 14:12 mtd-utils/include/mtd/mtd-abi.h
-rw-r----- r65388/s2101   1401 2010-01-15 14:12 mtd-utils/include/mtd/nftl-user.h
-rw-r----- r65388/s2101    516 2010-01-15 14:12 mtd-utils/include/mtd/mtd-user.h
-rw-r----- r65388/s2101   1674 2010-01-15 14:12 mtd-utils/include/mtd/inftl-user.h
-rw-r----- r65388/s2101  24520 2010-01-15 14:12 mtd-utils/fec.c
-rw-r----- r65388/s2101  50496 2010-01-15 14:12 mtd-utils/mkfs.jffs2.c
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd mtd-utils
+ echo 'Patch #1 (mtd-utils-201006-4K-218-224-support.patch):'
+ patch -p1 -s
+ exit 0
Executing(%build): /bin/sh -e /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178
+ umask 022
+ cd mtd-utils
+ make -j1 WITHOUT_XATTR=1
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o ftl_format.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.ftl_format.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o flash_erase.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.flash_erase.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall.o flash_eraseall.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.flash_eraseall.c.dep
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/crc32.o crc32.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.crc32.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/crc32.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o nanddump.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.nanddump.c.dep
nanddump.c: In function 'main':
nanddump.c:352: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:355: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:381: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:394: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:397: warning: ignoring return value of 'write', declared with attribute warn_unused_result
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o doc_loadbios.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.doc_loadbios.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o ftl_check.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.ftl_check.c.dep
ftl_check.c: In function 'check_partition':
ftl_check.c:107: warning: ignoring return value of 'read', declared with attribute warn_unused_result
ftl_check.c:82: warning: unused parameter 'verbose'
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/mkfs.jffs2.o mkfs.jffs2.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.mkfs.jffs2.c.dep
mkfs.jffs2.c: In function 'recursive_add_host_directory':
mkfs.jffs2.c:435: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:440: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:442: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c: In function 'interpret_table_entry':
mkfs.jffs2.c:533: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:600: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:601: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c: In function 'recursive_populate_directory':
mkfs.jffs2.c:1336: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1345: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1354: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1384: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1395: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c: At top level:
mkfs.jffs2.c:1519: warning: initialization discards qualifiers from pointer target type
mkfs.jffs2.c:1521: warning: initialization discards qualifiers from pointer target type
mkfs.jffs2.c: In function 'main':
mkfs.jffs2.c:1881: warning: passing argument 2 of 'recursive_add_host_directory' discards qualifiers from pointer target type
mkfs.jffs2.c:403: note: expected 'char *' but argument is of type 'const char *'
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_rtime.o compr_rtime.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_rtime.c.dep
compr_rtime.c: In function 'jffs2_rtime_compress':
compr_rtime.c:27: warning: unused parameter 'model'
compr_rtime.c: In function 'jffs2_rtime_decompress':
compr_rtime.c:67: warning: unused parameter 'srclen'
compr_rtime.c:67: warning: unused parameter 'model'
compr_rtime.c: At top level:
compr_rtime.c:104: warning: initialization discards qualifiers from pointer target type
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_zlib.o compr_zlib.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_zlib.c.dep
compr_zlib.c: In function 'jffs2_zlib_compress':
compr_zlib.c:54: warning: unused parameter 'model'
compr_zlib.c: In function 'jffs2_zlib_decompress':
compr_zlib.c:102: warning: unused parameter 'model'
compr_zlib.c: At top level:
compr_zlib.c:130: warning: initialization discards qualifiers from pointer target type
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_lzo.o compr_lzo.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_lzo.c.dep
compr_lzo.c:29:23: error: lzo/lzo1x.h: No such file or directory
compr_lzo.c: In function 'jffs2_lzo_cmpr':
compr_lzo.c:51: error: 'lzo_uint' undeclared (first use in this function)
compr_lzo.c:51: error: (Each undeclared identifier is reported only once
compr_lzo.c:51: error: for each function it appears in.)
compr_lzo.c:51: error: expected ';' before 'compress_size'
compr_lzo.c:54: warning: implicit declaration of function 'lzo1x_999_compress'
compr_lzo.c:54: error: 'compress_size' undeclared (first use in this function)
compr_lzo.c:56: error: 'LZO_E_OK' undeclared (first use in this function)
compr_lzo.c:49: warning: unused parameter 'model'
compr_lzo.c: In function 'jffs2_lzo_decompress':
compr_lzo.c:72: error: 'lzo_uint' undeclared (first use in this function)
compr_lzo.c:72: error: expected ';' before 'dl'
compr_lzo.c:74: warning: implicit declaration of function 'lzo1x_decompress_safe'
compr_lzo.c:74: error: 'dl' undeclared (first use in this function)
compr_lzo.c:76: error: 'LZO_E_OK' undeclared (first use in this function)
compr_lzo.c:69: warning: unused parameter 'model'
compr_lzo.c: At top level:
compr_lzo.c:84: warning: initialization discards qualifiers from pointer target type
compr_lzo.c: In function 'jffs2_lzo_init':
compr_lzo.c:95: error: 'LZO1X_999_MEM_COMPRESS' undeclared (first use in this function)
make: *** [/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_lzo.o] Error 1
rm /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o
error: Bad exit status from /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178 (%build)
RPM build errors:
Build time for mtd-utils: 2 seconds
Failed building mtd-utils
Died at ./ltib line 1380.
traceback:
 main::build_host_rpms:1380
  main::host_checks:1435
   main:542
Started: Thu Mar  8 08:57:19 2012
Ended:   Thu Mar  8 08:57:22 2012
Elapsed: 3 seconds
These packages failed to build:
mtd-utils
Build Failed
Thank you
