QT Creator 2.3.0
QT Creator 2.3.0
rmeyer_arrow
Hello I'm new to the i.MX area and to using QT.
I have been following the document here: http://imxcommunity.org/forum/topics/qt-4-7-4-embedded-spec-on-i-mx...
The demos are not running but I have that in a different discussion.
Right now I have built the Hello program and it ran on the host machine, Ubuntu 10.4LST.
I made the changes called for in the PDF from the link but when I try to compile now I get some build issues.
  • main.o: Relocations in generic ELF (EM:3)
  • could not read symbols: file in wrong format      main.o
  • collect2: ld returned 1 exit status
I have checked all the settings and they seem to be as described in the document but still get the errors.
Did I miss a step?
rmeyer_arrow
Thank you, I checked the path and it looked correct but I recently rebooted and now it seems to be working.
Not sure what was stuck.
KrishnaPavan
I got past through such errors, by using suitable compilers.
What about you?
