suvarna vellanki
MC9S12DP256 - Root cause for Flash corruption
Discussion created by suvarna vellanki on May 8, 2007
Latest reply on May 9, 2007 by Paul Pearson
Hi ,
we are working for Aerospace domain using the
MC9S12DP256 controller
where we are loading software into flash once and in our code we are performing EEPROM and RAM related operations when fight is in air. at that time Flash corruption is happening. After doing the Root cause analysis what we found was due to code run away problems flash corruption is happening and we added some programs which can initialize the data before writing into flash. But its not exact solution for this problem. So i want to know what could be the reason for flash corruption if the aircraft is in air. How we can avoid them ?
Thanks in advace,
suvarna.
Message Edited by chinni on 2007-05-08 09:43 AM
Alban Edit: split thread: new question = new thread + renamed to show part number
Message Edited by Alban on 2007-05-08 12:54 PM
