Thank you for the information.
It is interesting that you are fully supporting the 32-60k flavors but not 16k when they all came out the same time.
Not understanding what all the differences are at this point perhaps you can recommend the best path for me on this.
I see three options.
1) Start the project as an AW32 part and follow your PPT to change it to AW16. What else might need to be changed if I use processor expert this way?
2) Use the AW16 support as it is and manually figure out all the registers and such that PE would do for me.
3) Build protos with an AW48 (the AW32s do not seem to be available from Future or Digikey) and later re-target my code for a AW16.
We are building protos is 2 weeks so June is a bit late for me on this part.
Thanx
Rick
