mfgtool download FW failture
Davidkang
Hi all,
using L2.6.35_11.05.01_ER_source BSP,
1. Selection (imx5x)
2.Selection (mfg firmware profile)
3 Selection board (mx50_rdp)
after I use ./ltib to buid ,copy uImage to the folder :mfgtool\OS firmware\, and  download FW to EMMC,but it is fail ,the serial message is as below
UTP: sending Non-success to kernel for command mknod block
how to solve it?
best regards,
david kang
TimVerstraete
i have the same issue, how did you then fix this?
thanks in advance,
kind regards,
tim
Matteo
HI,
I have the same issues, have you solved the problem?
Matteo.
