Srinivasan
error tftp: not found in the android shell using ethernet while transfering a file in i.MX53 QSB
Discussion created by Srinivasan on Feb 15, 2012
Latest reply on Feb 19, 2012 by Srinivasan
Dear All,
I want to make use of the ethernet port available on the i.MX 53 QSB so i wanted to transfer sme txt file using tftp protocol
I have installed tftp server on my ubuntu PC using the below command
sudo apt-get install tftpd-hpa
then i was able to ping from the imx board using the ping 192.168.1.2 (where 192.168.1.2 was my ubuntu PC's IP address) & i was able to ping 192.168.1.3 (where 192.168.1.3 was imx board IP address)
Then when i wanted to transfer sme txt file called (for ex: tftptestfile.txt) using tftp protocol
I copied the txt file into the path in my ubuntu PC using the below command
sudo cp tftptestfile /var/lib/tftpboot
And when i wanted to transfer the tftptestfile into the imx board using the below command in android shell
tftp -r tftptestfile -g 192.168.1.2
I was getting the below error
tftp: not found
Could any body pls help me in providing with necessary steps in how to transfer the file into the android shell from my Ubuntu PC through tftp protocol using ethernet in IMx53 QSB
As am new to this platform kindly do the needful as soon as possible
Awaiting for ur replies,
Advanced Thanks,
Srinivasan S
