Solved! Go to Solution.
Hi there,
the process has 2 phases:
www.freescale.com/webapp/sps/site/overview.jsp?code=CW_LICENSE
the second point allows you to activate your license, provide the required information and the licensing department will send you an evaluation license file.
Note: the linux tools per default come with and empty license.dat file... nothing to do with the licensing process, nothing to be worry about.
Hope this helps...
Hi there,
Hope this helps...
Hi!
I'm one user of codewarrior for coldfire v6.3, registered for a long time. However, I haven't receiced the license code. Can you told me how you activated your license. Thank you!
Hello
I checked CRM.
Apparently your Entitlement ID starts with AAZB. Am I correct?
This one is associated with Codewarrior Development Studio, ColdFire Special Edition.
With this entitlement you do not need to activate your license. Special edition license file should be installed with the tool chain.
CrasyCat
