Meng Jin
What does "Hello World" do, and how to see the code behind it?
Discussion created by Meng Jin on Feb 8, 2012
Latest reply on Feb 27, 2012 by Renato Frias
Thanks for reply from Renato. This is Mike Jin from PSU again.
What does "Hello World" do if I can make everything work correctly?
I see the option to generate package, but how can I identify the C code corresponding to the helloworld pack?
How can I implement a pack and load into ltib SDK?
Is there any freescale solution for graphic? like QT, or lab view?
How can I setup cross compiler for gcc&g++ for imx53?
Mike Jin
PSU EcoCAR2/EcoCAR
