Davide Pierattoni
firmware upload on 13213 board with MCU 9S08AW60
Discussion created by Davide Pierattoni on Apr 27, 2007
Latest reply on May 16, 2007 by David Payne
Hi, I’m using Codewarrior 5.1 for programming 13213-SRB and 13213-NCB board.
First I load the Bootloader_embebbed with TestTool successful on either boards.
Then I load a demo application (Start Network Demo (Coordinator and End Devices)) with Freescale Beekit: I export these solutions for compiling and uploading the code.
With Codewarrior I import the file created with Beekit and create a new project: I specify the MCU model (HCS08, MCU 9S08AW60). I compile the code successful and when I try to upload the application on the boards with True-Time Simulator and Real-Time Debugger the tool stops with this message (during memory programming):
Error 18 during script!
Moreover the tool doesn’t erase the memory before programming.
In Codewarrior I use BDM programmer cable with USB Multilink interface.
I’ve tried many modifications, but no success.
Thank you
