Henri Bragge
Cannot boot from NAND
Discussion created by Henri Bragge on Feb 6, 2012
Latest reply on Jul 31, 2012 by sanu sv
I have i.MX53 SABRE for Automotive Infotainment (i.MX53 ARD) RevB and I'm trying to boot from a Micron NAND chip MT29F2G08ABAEA.
I cannot see any output from U-boot via serial console when booting. I have double checked dip settings (16bit ECC NAND). NAND is otherwise working, because I can read/write it from U-boot when I boot from SD card. Also the U-boot and serial console settings should be correct because it works when booting from SD card.
Is booting from this NAND chip unsupported? Is there compatibility list available somewhere?
