iMX535 based Quick Start board contains the MAC Address information is stored in IIM ( IC Identification Module ) fuses. U-boot has been provided with the following commands to change the mac address but the change is not effective.
"iim blow fecmac" command.
Advance thanks for your valuable inputs.
Hariharan.V.
NEE VEE Communication Technologies ( www.neeveetech.com )
iMX535 processor contains VDD_FUSE pin should be 3.2V for IIM Fuse Bits programming.
Configure of LDO of PMIC of ( DS9503 / LTC3589-1), provides the respective voltage.
Hariharan.V.
