Nagesh A
Using MFG tool to write JFFS2 type rootfs
Discussion created by Nagesh A on Jan 24, 2012
Hi all,
We are using i.MX53 SABRE SMD tablet.
We have used Freescale provided MFG tool to programme the Linux images, like u-boot, uImage, and rootfs.tar.bz2 to the eMMC4.4 card which is of size 4GB.
The MFG tool internally uses a script file in which it is basically creating a partitions using "dd" command and untar'ing the rootfs.tar.bz2 image in that partition.
But our requirement is to go for JFFS2 type rootfs.
I am not able to understand how it can be worked with MFG tool to flash JFFS2 type rootfs image.
Can anybody give suggestions over this ?
Is it possible to flash JFFS2 rootfs images in i.MX53 SMD tablet board ?
thanks in advance,
-Nagesh A
