Mahesh Mahadevan
Updated MM gst-fsl-plugin files for MX53
Discussion created by Mahesh Mahadevan on Jan 23, 2012
Latest reply on Jan 23, 2012 by Mahesh Mahadevan
Below are some updated files for the Freescale Gstreamer plugin for MX53. The files includes the below updates & fixes
[a] Add support to decode Black & White mjpeg files
[b] Fix issues seen with rotation when using the isink plugin
[c] Fix some flicker issues seen
[c] Allow negative axis values for the isink axis-* parameters.
  1. libs/vss/video_surface.c  (video_surface.c)
  2. libs/vss/video_surface.h  (video_surface.h)
  3. libs/vss/vss_common.h   (vss_common.h)
  4. libs/vss/vss_common.c   (vss_common.c)
  5. src/misc/i_sink/src/mfw_gst_isink.c  (mfw_gst_isink.c)
  6. src/misc/i_sink/src/mfw_gst_isink.h  (mfw_gst_isink.h)
  7. src/video/vpu_dec.full/src/mfw_gst_vpu_decoder.c   (mfw_gst_vpu_decoder.c)
Below are files needed to fix some upscaling issues seen when going from QVGA resolution to 1080p.The below files may be needed since one of the change in the vss_common.h file uses a define that is added in the below files
  1. imx-lib-11.05.01/ipu/mxc_ipu_hl_lib.c (mxc_ipu_hl_lib.c)
  2. imx-lib-11.05.01/ipu/mxc_ipu_hl_lib.h (mxc_ipu_hl_lib.h)
-Mahesh
