Leon Woestenberg
Qt "affine" demo w/ OpenGL: Unable to create EGL context: "Bad alloc (0x3003)"
Discussion created by Leon Woestenberg on Jan 22, 2012
Latest reply on Feb 1, 2012 by Ben Beckwith
I built Qt for i.MX53, and run the Qt "affine" demo, which is the spinning vector Tux penguin.
Then I press the "Use OpenGL" button using the mouse.
However, it fails:
sh-4.2# /usr/bin/qtopia/demos/affine/affine -qws
QEglContext::createContext(): Unable to create EGL context: "Bad alloc (0x3003)"
QGLContext::makeCurrent(): Cannot make invalid context current
QGLShader: could not create shader
Vertex shader for simpleShaderProg (MainVertexShader & PositionOnlyVertexShader) failed to compile
Fragment shader for simpleShaderProg (MainFragmentShader & ShockingPinkSrcFragmentShader) failed to compile
QGLShaderProgram: could not create shader program
Errors linking simple shader: ""
Vertex shader for blitShaderProg (MainWithTexCoordsVertexShader & UntransformedPositionVertexShader) failed to compile
Fragment shader for blitShaderProg (MainFragmentShader & ImageSrcFragmentShader) failed to compile
Errors linking blit shader: ""
Warning: "" failed to compile!
I am fresh to OpenGLES on iMX, can someone spot where this might be caused?
Leon.
