Shaojun Wang
Enable 1366x768 LVDS screen on MX53 LVDS 0, Android R10.3.1
Discussion created by Shaojun Wang Employee on Jan 10, 2012
Latest reply on Feb 28, 2013 by Soujanya K
1. Kernel change
diff --git a/drivers/video/mxc/ldb.c b/drivers/video/mxc/ldb.c
index 088d36a..b49ef28 100644
--- a/drivers/video/mxc/ldb.c
+++ b/drivers/video/mxc/ldb.c
@@ -123,6 +123,7 @@ struct fb_videomode mxcfb_ldb_modedb[] = {
         0,
         FB_VMODE_NONINTERLACED,
         FB_MODE_IS_DETAILED,},
+#if 0
         "XGA", 60, 1024, 768, 15385,
         220, 40,
@@ -131,6 +132,17 @@ struct fb_videomode mxcfb_ldb_modedb[] = {
         0,
+#endif
+        /* 1366x768 @ 60 Hz 162M pixel clk*/
+        //" WXGA", 60, 1366, 768, 13255, // 75.44MHz
+        "WXGA", 60, 1360, 768, 13255, // 75.44MHz
+        190, 10,  // 194
+        30, 8,   // 38
+        65, 12,
+        0,
+        FB_VMODE_NONINTERLACED,
+        FB_MODE_IS_DETAILED },
 int mxcfb_ldb_modedb_sz = ARRAY_SIZE(mxcfb_ldb_modedb);
@@ -433,7 +445,7 @@ static int ldb_fb_pre_setup(struct fb_info *fbi)
        int ipu_di = 0;
        struct clk *di_clk, *ldb_clk_parent;
-       unsigned long ldb_clk_prate = 455000000;
+       unsigned long ldb_clk_prate = 528080000;
        fbi->mode = (struct fb_videomode *)fb_match_mode(&fbi->var,
                        &fbi->modelist);
This change is for 1366x760 screen.
Since IPU IC require the input/output width must be multiple of 8, so set the screen width to 1360, rather than 1366.
528080000 is 7 times of pix clock, 75.44MHz
2. Android change
In init.freescale.rc, change “setprop ro.AUTO_CONFIG_DISPLAY  1” to “setprop ro.AUTO_CONFIG_DISPLAY  0”
This change is for LVDS0.
3. U-boot command line change
console=ttymxc0 init=/init androidboot.console=ttymxc0 video=mxcdi0fb:RGB666,WXGA ldb=di0 di0_primary ip=dhcp gpu_nommu, gpu_memory=64M
