New Linux 11.09 BSP Patch for the i.MX53 -blog archive
EnriqueOchoaVaz
Contributor V
The new i.MX53 Linux 11.09 patch is now available on the www.freescale.com page.
Name
Description
Web Link
IMX53_LINUX_1109_BSP_PATCH
Patch based on L2.6.35_11_09_ER_SOURCE, to provide: GPU driver update, Uboot update for plug-in mode support on Ripley QSB, VPU firmware update and other fixes
Link
IMX53_1109_LINUX_MMDOCS
Linux Multimedia Codecs Documentation. Includes CODECs Release Notes and User's Guide
Link
IMX53_11_09_LINUX_MMCODECS
Linux Multimedia Codecs Documentation and Sources 11.09 for i.MX53 for the Quick Start boards.
Link
AACP_CODECS_LINUX_11_09
AAC Plus Codec for Linux 11.09.
Link
Note:The codecs packages have been updated , the revision number and the date of the packages were updated to reflect the changes.
  •  Target HW boards
    • MCIMX53-START-R
    • MCIMX53-START
  • Issues solved
    • BSP part:
      • Uboot update for plug-in mode support on MCIMX53-START-R
      • Reset set to 4s
      • GPU microcode update with version 1020, The new GPU driver fix a random GPU hang issue that happens when a 3D application is running when the external memory bus is heavy loaded by other applications.
      • DMA zone increase to 112M
      • I2C fix : reboot  I2C instable issue
      • Dialog fix
      • VPU firmware update
      • Bug fixes
    • MM part
      • Bug fixes
  • What are the main issues left
    • For known issues and limitations please consult the release notes.
HenriBragge
How much do you encourage moving to 2.6.38? How well is different i.MX boards supported and tested, compared to 2.6.35.3?
KrishnaPavan
For Example ::
user@ubuntu:~/imx53/11.09.01/ltib$ cat ltib-fix-rpm-flag.patch
user@ubuntu:~/imx53/11.09.01/ltib$ patch -p 0 < ltib-fix-rpm-flag.patch
Open the patch file, you will find all the modifications, relative to patching of files.
Vinay_123
Dear  Enrique Ochoa Vazquez,
How are we going to update that patch in BSP. And how to verfiy whether patch is updated or not.?
Vinay Kumar
